Up for sale is my 11 year owned 2004 DBP .:R32. During those 11 years I have driven 35k miles. Current odometer is 114k. Has been garaged most of its life. Located in Wisconsin. Is my summer/fun car and is not driven in winters.
Turbo kit is CTS kit. Precision 6266 t4 v-banded turbo. 550cc injectors. Supporting motor work is headspacer 8:5:1 compression, raceware headstuds, APR piston rod studs, and crankshaft studs, 2 fuel pumps, one in tank, and other inline. United Motorsport tuned Ecu. Don’t know dyno numbers. 15 psi. Others claim 15psi is good for 400-450 Awhp.
has a clean title. Here is carfax report
https://www.carfax.com/VehicleHistory/p/Report.cfx?partner=BTR_0&vin=WVWKG61J94D093324&source=BUP
R32 parts
Suspension:
PSS9 Bilstein Suspension
Engine:
Timing chain and guides replaced at 85k
ECS billet coolant pipe
32DD oil catch can
2 fuel pumps, one inside gas tank and one inline in engine bay. High flow for both.
Hand Polished engine cover
SAI delete. Billet cover in place
Vibra-tech street/strip engine mounts
ECS dog bone engine mount
Raceware head bolt studs
ARP piston rod studs and crankshaft studs
Mishimoto billet aluminum radiator
Turbo parts:
CTS stage 3 turbo kit with upgraded precision 6266 t4 vbanded. Intake side is .60 exhaust is 1.06
CTS log manifold v band
Precision 44mm wastegate, have extra springs and manual. Current spring is 11psi, controller is set to 15 psi
CTS head spacer 8:5:1 compression
CTS v band 3” down pipe
Catalytic converter test pipe
550cc injectors
3 inch MAF housing
UM turbo tune for Ecu. Has no lift shift, launch control and emission delete. Also this tune coded out some emissions like the SAI delete and rear 02 sensor data. Emission monitors no longer have a drive cycle to make monitors “ready”.
3” Billy Boat cat back exhaust
Exterior:
Euro R-Line Front bumper (side marker delete)
Euro front bumper grill pieces (see-thru)
Stereo:
Alpine IVA-W505 head unit
Kicker 4 Channel Amp
JL Audio W3 10”
Speakers in doors are name brand and have been replaced. Kicker maybe?
Drivetrain:
Blue Haldex Controller
Raxles 1/2 shafts for fronts
Transmission:
Clutchmasters 650 clutch
Output shaft spacer/shim, stock has slop and vehicle would creep forward in neutral. No longer an issue with shim
Lightened flywheel instead of stock dual mass.
Brakes:
EBC red pads
Brand new OEM front rotors, less than 3000 miles
Tires:
225/40/18
Bridgestone potenzas re 970
All tires wear evenly but at 4-5/32nds
Spacers, 5mm front and 15 mm rear
Interior:
Audi S4 rear seat headrests
VW beetle middle rear seat headrest
AVO turboworld electronic boost controller (have manual)
New south boost gauge (matches instrument color lighting)
APSX Wideband O2 gauge and sensor
Innovate LC-1 wideband is for LED wideband display in vent. Not reading correctly, can be tuned to read correctly though. Manual included
.:R monster floor mats
Stock parts:
Have a throttle body OEM. Used
Have extra coil packs OEM used
Have stock floor mats
Have manuals for some stuff.
Have battery cover
$24,000
1-920-912-1456
text preferred but can call too. Have tons of pics to share
