AMI is pleased to announce that the Solo Werks coilovers are NOW IN STOCK for MK2 through MK6 VW's!!!!
Solo Werks uses the spring rates and matched valving you are looking for to give you the Lowering & Ride you want on your VW! :thumbup:
Here are the full details:
^MK5/ MK6 Golf / Jetta / Passat Sample kit pictured above^
Solo Werks S1 Coilover System - Premium Entry Level Coilover Suspension!
Solo Werks kits feature:
- Gold Heavy Zinc Plated Housings for superb corrosion resistance
- Silver spring perches - double lock ring design
- Platform Specific Spring Rates and Matched Valving
- Front & Rear 35-85mm (1.4-3.3") Lowering Range (application dependent)
- Shortened Sway Bar End links (when necessary)
- 3 year Limited Warranty
Each Kit can contain (depending on application):
- 2 Front Threaded Coilover Dampers -Heavy Gold Zinc Plated with dual locking ring spring perches
- 2 Front Springs+2 Helper springs
- 2 Front Microcellular Bump Stops
- 2 Rear Dampers
- 2 Front Swaybar End Links*
- 2 Rear Adjustable Perches
- 2 Coilover Spanner Wrenches
Designed by a joint engineering staff from Germany and the USA, the S1 coilover is built for the enthusiast that is looking for an ideal balance of ride quality and performance.
The front the S1 coilover for the MK5/6 VW/Audi Group platform features a specially designed progressive spring or linear rate spring & helper spring combined with a valving matched twin tube low pressure gas damper mounted in a new heavy gold zinc plated threaded coilover housing that provides not only great handling, but also exceptional corrosion resistance.
The rear features a progressive coil spring & adjustable threaded perch system, or linear race spring and helper along with a specially tuned sport damper or threaded body coilover that is matched to the lowering range of the coil/perch combination.
Solo Werks has added many applications to its lineup, and now has applications to cover 95% of all VW's sold in North America!
Solo Werks applications are NOW AVAILABLE for:
VW
MK2 - All 2wd
MK3 - All 2wd
MK4 - Golf, Jetta Sedan & Wagon, Beetle - 2wd and AWD
MK4 R32
MK5 Golf, GTI, Rabbit, Jetta Sedan & Wagon, EOS - All Motors 2wd and AWD
MK6 Golf, Rabbit, Jetta sedan & Wagon, EOS - All Motors 2wd and AWD
Passat B3/B4
Passat B5/5.5
Passat B6 Sedan & Wagon - 2wd and AWD, All Motors
Passat B7
CC - 2wd and AWD, All Motors
Tiguan - All
Audi
MK1 Audi TT - 2wd and AWD, All Motors
MK2 Audi TT - 2wd and AWD, All Motors
MK2 Audi A3 - 2wd and AWD, All Motors
B6/B7 Audi A4- 2wd and AWD, All Motors
BMW
3 Series - 2wd All motors (non M)
E36
E46
E90
To get your own set of Solo Werks Coilovers:
1. Click Here to Go directly to the complete Solo Werks listings on our website and Buy Online!
2. PM or Email us your email address and we can send you an E-invoice that you can pay via PayPal, Visa, MC, Amex or Discover
3. Give us a call directly at 1-888-362-3117 x 101 M-F 9-5 PST and we can process your order over the phone ( Visa, MC, Amex or Discover)
We look forward to hearing from you!
Glen @ AMI :beer:
*Shipped price is within the lower 48 states only. Contact us via PM, Email or Phone with your ship to Zip/Postal code and we can get you the best price delivered to you. - WE SHIP WORLDWIDE!!!!!
