1 - 20 of 210 Posts
At long last Solo Werks has released the CC - MK5/6 platform S1 Coilovers!
We are offering these complete coilover kits for:
Lower 48 states - $499 shipped within the
Hawaii / Alaska / PR - $559 shipped
http://www.amimotorsports.com/store/cart.php?m=product_detail&p=7548
Canada: $575+GST/HST shipped (all duties and taxes are taken care of by AMI)
Click Here to Order
We have again had the pleasure of performing the Beta testing and first installation on this kit on a clean MK5 Jetta 2.0 DSG and have the measurements and data over and above the manufacturers specs :cool:
The specs for the CC platform will be the same for the min max numbers :thumbup:
Here are the specs / details on the kit:
Features at A Glance
Solo Werks S1 Coilover System - MK5 and MK6 - Premium Entry Level Coilover Suspension!
  • NEW FORMULA Silver Zinc Plated Housings for superb corrosion resistance
  • Silver spring perches - double lock ring design
  • Platform Specific Spring Rates and Matched Valving
  • Front 35-55mm (1.4-2.2") Lowering Range
  • Rear 35-70mm (1.4-2.75") Lowering Range
  • Includes shortened Sway Bar End links!
  • 3 year Limited Warranty
Each Kit contains:
  • 2 Front Threaded Coilover Dampers -NEW FORMULA Silver Zinc Plated with dual locking ring perches
  • 2 Front Springs+2 Helper springs
  • 2 Rear Dampers
  • 2 Front Swaybar End Links
  • 2 Rear Adjustable Perches
  • 2 Coilover Spanner Wrenches
Please note, you must reuse your factory bump stops/dust boots with this kit.
Here is the Beta Test car in its testing:
Stock height:
At the Solo Werks lowest "recommended lowest setting - 55mm front 70mm rear":
The Hub to Fender measurements for the Solo Werks Recommended max lowering:
Solo Werks Posted Lowering ranges:
AMI Tested max drop:
AMI Tested max drop measurements:
  • Tire size as tested is 225/45/17
  • The max lowering shown in the tables above is achieved at the lowest position of the threaded adjustment on both front and rear axles.
  • Helper Springs have been retained and should not be removed! See notes below on the Helper Springs.
  • These measurements allow for the shock absorbers both front and rear to have the minimum amount of travel required by the engineers to do their job before full bump stop engagement.
  • Depending on your wheel and tire combination, you may need spacers to clear the coilover perch/springs. SOLO WERKS recommends at least 5mm clearance in this case.
  • At the lowest level with some wheel/tire combinations, you may need to modify one or more of your body panels to allow for sufficient travel of the wheel inside the fenders. Please ensure that you have clearance from all obstacles through the complete travel of the wheels.
NOTES: The Helper springs are there to keep tension on the main spring during full extension of the shock absorber.
The main spring is not long enough on its own to keep the shock at full extension.
Removal of the helpers will result in the main spring being able to travel away from its upper and lower spring perches, and will result in damage to your suspension as well as other components.
DO NOT REMOVE THEM!!!
Discussion Starter · #2 ·
Thanks to everyone for their questions & orders!
Our shipping department is busy getting your kits shipped this afternoon for everyone who has ordered as of 3:00PM pacific time today, watch your email for tracking :thumbup:
Let us know if you have any questions!
Glen @ AMI :beer:
Discussion Starter · #7 ·
Hello Everyone.
If you are interested in reviewing a Solo Werks kit on your CC, we are interested in speaking with you!
PM us with previous review / post history on a product either on this forum or another car forum and we will review your content and select one vortex member for a subsidized kit :thumbup:
We look forward to hearing from you!
Glen @ AMI
Discussion Starter · #8 ·
Thanks to everyone who ordered last week!!!!
All orders that were received before 3 PM pacific time on Friday have been shipped, and your tracking information should be in your inbox (check your junk folder just in case!) :thumbup:
All Questions have also been responded to that have been received as of Saturday evening.
Thanks!
Glen @ AMI :beer:
Discussion Starter · #9 ·
Thanks again to everyone who ordered over the weekend!
All kits are on their way that were ordered before 2:30 PM today :thumbup:
For those who have ordered, do not forget to post your reviews online on Vortex or other forums and email your ship to info & Shirt Size into Solo Werks ([email protected]) along with the link to the thread and they will get a Solo Werks coilover shirt sent out!
Glen @ AMI :beer:
Discussion Starter · #10 ·
Our shipping department is really busy trying to get out all the orders today!
They get a bit carried away, but they are pretty sure they can get everyone's order that was placed in the last 24 hours out today!
Orders shipping out today will have tracking emailed to them via our automated system + UPS/FedEx :thumbup:
Keep the questions coming! :peace:
Glen @ AMI
Discussion Starter · #11 ·
Another great day!
As always, all orders received before 3:00 PM pacific time are in process and will be shipping today and tracking information will follow - watch your email boxes for the info (and check your Junk folder just in case)
Thanks!
Glen @ AMI :beer:
Discussion Starter · #13 ·
Online there isn't cc listed? How do I order CC ones
Its there :) On our webcart link: Click Here
In the description (scroll all the way to the bottom), CC is listed 4th from the bottom :thumbup:
Thanks!
Glen @ AMI
Discussion Starter · #14 ·
After I posted I realized that you were probably referring to the Year Make Model look up, and that there was not a CC category.
I have had that fixed, and the S1 Coilovers have been categorized!
thanks
Glen @ AMI
Discussion Starter · #16 ·
TGIF!!!!
All orders that were received before 3PM today are on their way via UPS / FedEx :thumbup:
We will be in and out of the office this weekend, so don't hesitate to send us a PM or email!
Have a great weekend!
Glen @ AMI
Discussion Starter · #17 ·
Saturday Update. :cool:
All PM's and emails have been responded to and all orders processed in the warehouse.
Thanks!
Glen @ AMI :beer:
Discussion Starter · #18 ·
Thanks to everyone who Ordered, PM'd or sent in Emails over the weekend :thumbup:
All orders placed by 3:00PM today are on the shipping doc ready for pickup by UPS for domestic or FedEx for International - tracking numbers to follow in your inbox later tonight :cool:
Let us know if you have any additional questions
Thanks again,
Glen @ AMI
1 - 20 of 210 Posts
