Solution to my acceleration/CEL problem
586 Views 4 Replies 3 Participants Last post by  Vickers
The following were items I was told to look at:
timing belt
vacuum lines
loose throttle body
clogged injector
dirt in fuel line
bad MAF
dirty MAF
camshaft position sensor
Neuspeed valve
distributor/cap (N/A)
plugs
plug wires seated properly
MAF wiring
injector seated properly
fuel pump
fuel pressure regulator
coil pack (N/A)
leaky injector
fuel rail
ECU
I checked all of the things in the list below that I could, even changing out ECUs and a MAF with a friend. No dice.
I had also thought it might be a bad tank of gas, but I get gas at the same place 99% of the time, and even after I filled up and took it for a spin the problem remained.
I ended up getting a VAG-COM and it just said cyclinder 3 was misfiring, which led me back to my original suspicions, the plugs and the wires. I had already changed the plugs (Bosch) and it cleared it for a bit, then the problem returned.
So I went and got some new plug wires. And that was it.
And there was a funny thing about the original plug wires. If you go out and look at how your plug wires are labelled, it goes like this:
A - 1
B - 3
C - 2
D - 4
The number is towards the plug and the letter is on the boot by the ignition module.
Anyway, the plug wires on mine said
A - 1
B - 3
B - 2
D - 4
So, the meathead who did the substandard work on the plug wire grabbed the wrong boot and then made a crappy connection. Lasted for a few months, but eventually was not good enough.
At least I have a VAG-COM now.
Here is the original thread:
http://forums.vwvortex.com/zerothread?id=141081
Vickers
P.S. For those of you who think the Wolfsburg-built cars are superior, my plug wires, and the car, were made in Germany. So much for that myth.
See less See more
1 - 5 of 5 Posts
Re: Solution to my acceleration/CEL problem (Vickers)
Oh, and to top it off:
As soon as I put the plug wires on (and double-checked everything) I cranked it up, it idled for a moment...and the CEL went off. I was ecstatic.
Ran to the house, yelled to my wife that I had it fixed and was going to take it for a spin. Hopped in, buckled up, let the windows down:
and the driver's side window fell into the door. 4th time that has happened.
Took it to the dealer; they fixed it under warranty since that side was last repaired in May (the passenger side went out in July).
Vickers
Vickers, were these your OEM wires or did you have aftermarket? What kind are the new wires?
Re: Solution to my acceleration/CEL problem (JettaRed)
Happy to see your problem is fixed!
See less See more
JR, was gonna order but ended up getting new wires from dealer ($49). Worked like a charm, and much better construction than the originals (must've been Oktoberfest or something).
Golf_2K2L, you and me both!
Vickers
1 - 5 of 5 Posts
