Hi guys, I joined Vortex a very long time ago when i used to restore classic (70's) Beetles. This year i bought the wife a 2001 1.6 petrol "new" Beetle, and its brought nothing but joy for her (misery and pain for me lol) and the last problem in my long list of things I need to close out is a running issue with the IAT Inlet Air Temp sensor.
EDIT - I should also add, the car struggles to start sometimes, and runs rough until its warmed up at which point it drives beautifully. It does however, seem to be using a lot of fuel!
Essentially at startup the OBD reports a P0113 fault, and when monitored shows a constant air temp of -40deg C.
Air flow fluctuates nicely with revs - around 2g/sec at idle.
Work done so far:-
My gut feel is there is either an issue with Fuel Pump 409 Relay, or an ECU issue where i should be getting a 5V signal feed.
Am i barking up the wrong tree, or is there something else i should be checking out? All advice / guidance / mental health support welcome!
Thanks
Rob
Work done so far:-
- XC MAF with 'good' 2nd hand spare
- tested fuses 43, 163 - OK
- Can't find a wiring schematic for 4-wire Bosch MAF but, Pin 3 gives 12V (13.8V actual when running)
- Can't find a 5V feed on the MAF connector.
Thanks
Rob
