1 - 17 of 17 Posts
I've loved these rims for a long time and finally I found someone who put them on his GTI, now I want to see them on a Corrado. I'd do it myself but alas I just got new rims, one problem is the size, they are 17x8 and would need an adaptor so a little fender work would be in order, not sure of ET.
Here's a pic:
Does anyone have a pic of these on a C?
Which wheels are those? Do you know anyone who sells them?
Re: Someone please put these BBS on your C (todye4)
Those are the BMW 5 series BBS rims. 17x8 and 5x120 bolt pattern with an ET of 20. On a Corrado they'd poke out quite a bit with adapters. BBS made a version for the BMW 3 series in a 17x7.5 size with an ET of 41 - same design but the lip is much smaller. The 3 series version are what I've got sitting in the garage waiting to go on the Corrado as soon as new tires show up.
I'm sure those are the BMW 5 series BBS oh $HIT those are HOT!
Re: Someone please put these BBS on your C (Riderx56)
Quote, originally posted by Riderx56 »
thats correct, but perhaps they can be redrilled? so as not to use an adapter?
Re: Someone please put these BBS on your C (T0oDamnFast)
you'd have to redrill or else you'd be sitting at et 0 or -5 on a 8" rim... major fender work required to run those with adaptors.
Re: (1SlowSLC)
Quote, originally posted by 1SlowSLC »
factory 17" bmw 5 series sport wheels. the model is a BBS RS. the offset and width make it difficult to use on a vw because of the adaptor neede to go from 5x100 to 5x120. these wheels can also be found in 5x100 with correct vw offset but for around 2500 a set, without tires. model # RS301. search for Mr.Ginster in the mk3 forums, he had a set. they were originally made for the corrado race cars in europe http://****************.com/smile/emthup.gif
Discussion Starter · #11 ·
Re: (93ceedo)
Quote, originally posted by 93ceedo »
too much MKIV content.
thanks for the bump
Quote »
Please post up a pic when you get them on or if you have a pic of them now.....post it up.
Discussion Starter · #12 ·
Re: (1SlowSLC)
ebay, bid away mad man.
http://cgi.ebay.com/ebaymotors...38662
I remember Mr. Ginsters car, have the PVW poster, 5x100 huh hmmmm.
Redrilling would be the way to go I guess, cheaper than 2500, no fender work, and no adaptors.
Re: (slomofo.)
Remember don't confuse these with the BBS RS wheels that Niko sells. Those are 3 piece wheels and are much stronger. The BMW versions are just 2 piece wheels (with a plastic center cap) and I have heard from other BMW owners that they are still pretty soft - reminiscent of the soft BBS RM wheels that came on the GTi's a few years back - pretty but not very durable. Definitely not as robust as the RS's.
Re: (Riderx56)
the 5 series wheels carry an RS part number under the center cap and are 3pc. you may be thinking of the 2pc. 3 series wheels
Re: (slomofo.)
No, the BMW's may carry an RS number but they are definitely two piece construction. The 3 series and 5 series Style 5 wheels consist of the barrel and then the rim face which is bolted to the barrel. The barrel itself is not made up of two halves like the RS301s. I did a lot of research to get the 5 series to fit on a Corrado and finally settled on the 3 series version to avoid redrilling holes.
Check the parts below and you'll see what I mean.
http://www.circlebmw.com/parts/wheel98/wheel98.htm
http://www.pacificbmw.com/cata...id=11
Re: (Riderx56)
oh i see, well that's no good. i do like how much lip though.
1 - 17 of 17 Posts
