I ordered these a couple weeks ago and finally had a chance to install them.
They are getting installed on my 2015 S 2 door GTI, which is not a Fender system.
TL;DR review = these things are awesome. I'm super happy with the purchase. They installed quickly and easily and are a major upgrade over the stock speakers. Granted, I'm a 31 year old male, so probably I care more about sound quality than deep, door rattling bass like sound younger kids might. I'm still not sure if I'll end up adding a sub or not, but for now, these will keep me happy for a while. Two thumbs up and would recommend.
Full review: I PM'd Soumatrix on VWvortex to setup an order and they got back to me fast. I decided to go with the Xtase as I figured if I was going to take the time to do it, I might as well go all out. They retail for $796 shipped from Soumatrix's website. I placed the order and in a few days had my stuff.
Lets start with what arrived:
Looks like each set comes with some sound deadening material, which I was not expecting, so that's a nice bonus.
Set of Xtase speakers.
Couple of extra panel clips (because you know you're going to break some) and rivets for the reinstall.
Now lets compare the Xtase to the OEM stock speakers.
The stock speaker is decent, but it clearly has a weak cone. The label indicates its 20W.
The Xtase is a big jump in quality. Much nicer cone and of course the added tweeter. The solidness of the speaker compared to stock is apparent as well.
Quality seals around the edges.
The magnet feels heavier (I should have weighed them for verification) and the label indicates 40W.
Install
Tools needed:
Trim removal tools
Hex ratchet set
Rivet gun
Flashlight
Drill and small drill bit
Pliers
Strong hands
Difficulty:
Easy to moderate, depending on experience
Time needed:
Two hours
Start with the front doors.
First remove the door pull covers by sliding in a trim tool and working your way down.
Remove the bolt here behind the door pull cover.
At the base of the door pull, there is another bolt that needs to be removed.
On the bottom of the door pull is this bolt. It does not need to be removed, just twisted 90 degrees so the door card can be removed.
Once the bolts are removed, start working your trim tool all the way around the door card and freeing the clips. Don't be scared to use a little force here. Once its loose, start pulling away with your hands.
After you've pulled the door card out, you'll need to disengage the tabs that supply power to the door locks and all the lights up front. I did not remove all of them, just enough for me to set the door card aside.
Now we've got access to the speaker.
Start drilling out the rivets. Once they've been drilled, remove them (be sure to remove any bits that have fallen into the door so they don't rattle. A magnet helps here. Pull out the OEM speaker.
Use the supplied padding, remove the sticker side, a place it behind where the speaker will be installed.
Take your rivet gun and use the supplied rivets to install the new Xtase speaker.
Cut the sound deadening material down to size.
I covered up any holes in the door. I'm sure pros could find better uses for this stuff, but I had absolutely no rattles after I buttoned everything up, so I'm happy with my placement.
Before you reinstall the door cards, double check and make sure the speakers work. Even with just two speakers installed, its a HUGE difference over stock. Carley Rae Jepson sounds fantastic. :laugh:
Install
Tools needed:
Trim removal tools
Hex ratchet set
Rivet gun
Flashlight
Pliers
Strong hands
Difficulty:
Time needed:
Two hours
