1 - 4 of 4 Posts
Discussion Starter #2
And...It's in!
I'll re-attach the Setrab oil cooler, and the Secondary Air Pump (minus the bracket end of same that bolted to the oil pan), wire up the oil pressure gauge, and I'll start the re-assembly of the front bumper.:cool:
Discussion Starter #3
Here's the final sensor arrangement:
I was able to get 2" separation at the top, and 1 1/2" separation at the bottom of the oil cooler: that should be "cooler!"
Added the Addinol 5/40, burped the coolant...And, I finally installed this Oettinger grille I got from a local forum member years ago...And, hit the pavement to see how it played! So far, so good: oil pressure at cold startup is 60psi, and at operating temp (180 degrees open thermostats) idle, 20psi. I'm happy!
1 - 4 of 4 Posts
