1 - 15 of 15 Posts
Hi. It's time to replace my spark plugs and I went to the dealer and they wanted $70 for a set of 4!! What plugs do you all use or reccommend? I have an APR chip w/ stock/91/93/100, Forge 007, K&N drop in and a GHL 3" Turboback exhaust. Are the factory plugs the best to use?? Thanks.
Re: Spark Plug Question (soulman978)
i have NGK BKR7E's. I like them and they are cheap. The Autolite 3922s work well also. They are both a heat range cooler than stock, which is good if you are chipped. Gap them at .028.
There are a lot of good thread on chips if you search though.
Here's the list from the 1.8TFAQ. I've used the autolite 3922 and the Denso IK22's
--Common replacements
Autolite 3923
Autolite 3922 (one heat range colder)
Denso Iridium IK20
Denso Iridium IK22 (one heat range colder)
Bosch F7LTCR
NGK BKR7E (Race plug, one range colder)
*avoid BKR7E-11 as the factory gap is too large, .042*
Re: Spark Plug Question (JettaX01)
I recently just purchased some Denso's IK20's My old ones were looking like this when I pulled them out.
Modified by A1.8T at 7:51 PM 2-12-2004
I'm sure they will work but you won't get optimal combustion. Stick with the suggested plug unless chipped.
Modified by 1.infiniT at 6:48 PM 2-12-2004
Modified by 1.infiniT at 8:22 PM 2-12-2004
Re: Spark Plug Question (tazUSC)
i'd reccommend the NGK BKR7E.
i just put some autolite 3922's in my ride (torqued to 22lbs) and it ran great..........until the #1 coil popped up a couple of days later.
Re: Spark Plug Question (Seanathan)
Quote, originally posted by Seanathan »
That has nothing to do with the sparkplug...
maybe, maybe not. coincidence or not, it seems that it is more likely to happen if you run the autolites.
Re: Spark Plug Question (cbring)
Quote, originally posted by cbring »
The Autolite contact end of the plug MAY be to small for the coil to hold onto but I thought those push in coils were held in place by friction of the press fit (press into the valve cover).
On a couple of occasions I have removed my coils (old skule bolt ons) to check my plugs and I found one or two loose (autolites).
1 - 15 of 15 Posts
