Re: Spring w/ shocks or w/o shocks? (catalytic)
and in addition to wearing the shocks out faster, it'll ride like crap.
The stock dampers are just *barely* adequate to handle the soft
stock springs. Virtually all aftermarket springs are higher rate
so they'll just abuse the stock dampers to death.
As the post above shows, you'd be better off getting new dampers
and using them with the stock springs than the other way around.
But if you're going to have the struts out you might as well
replace the springs at the same time you throw in better dampers.
That's just the way it works. Save your money for another month
or two, and you'll be much happier.
ian
