1 - 6 of 6 Posts
In the past few weeks I've noticed that my suspension has gotten rather squeeky. When I get in the car or it moves up and down a bit I can hear the noise... I don't really hear it when i'm driving and the ride hasn't changed.. but i've been driving downtown a lot and there are some nasty potholes...
wondered if anyone else has experienced this (maybe i just need to WD40 them?)
Re: Squeeky Suspension?? (Terragen)
Don't use WD40... while it quiets squeaks initially, they tend to develop a lot worser as time progresses due to the degreasing agents in the lubricant.
Mine creeks like the doors in a frankenstein movie when I jack the car up and the wheels drop to top out on the shocks in the rear.. or when I put it back down and the spring compresses. Its only in the rear and no noise while I drive...
Thought of greasin it up.. but then brake dust and dirt that gets caught in the grease could make things worse down the road!
mine squeeks all the time...especially when driving slowly, turning slowly, going over driveway curbs, things like that....
not sure what the problem is either
Re: Squeeky Suspension?? (KMAKAZ_GTI)
Try a Graphite based spray lubricant. Similar to WD-40 but contains no oil. Crappy Tire sells it.
I I just tried this yesterday and it instantly illiminated ALL sweaks instantly!
I had just installed a set of polyurethane motor mounts (ES) a few days before and the sqeaking was driving me nuts. So much so that I was about to go back to the original ones. Then I figured I try the Graphite lube as a last resort and voila! No more squeaks!
ps: ES motor mounts work awesome btw!
Problem is some sort of bushings had mine done under warranty and they are now doing it again, I can duplicate it by pressing over tires on car.
1 - 6 of 6 Posts
