1 - 7 of 7 Posts
My bro just got a sentra SE-R and eveything is so tight. Clutch travel is pretty short and the accelerator has pretty good feel. Then I get in My Jetta and its like a marshmellow. The accelerator pedal is to soft and the clutch travel is like 50 miles, is there any way of adjusting it?
Re: Squishy Jetta (surefooted)
2.0 or VR6, the answer will be the same. The clutch is self-adjusting, so nothing to do there. And your throttle cable may be loose or something. Check to see if there is any slop at the throttlebody. Hope this helps!
Passatrcr
Discussion Starter · #4 ·
Re: Squishy Jetta (passatrcr)
quote:[HR][/HR]2.0 or VR6, the answer will be the same. The clutch is self-adjusting, so nothing to do there. And your throttle cable may be loose or something. Check to see if there is any slop at the throttlebody. Hope this helps!
Passatrcr[HR][/HR]​
Well, accodring to the dealer ship, everything checks out. Everything is so gosh darned soft! So theres no way to decrease the travel of the clutch?
Re: Squishy Jetta (RJetta8V)
Passatrcr
Well, accodring to the dealer ship, everything checks out. Everything is so gosh darned soft! So theres no way to decrease the travel of the clutch?[HR][/HR]​
ok marshmellowy clutch, deal with it.. do the doors on the sentra actually thwump when u shut them ot is it tinny?
Discussion Starter · #6 ·
Re: Squishy Jetta (XSiVE)
quote:[HR][/HR]ok marshmellowy clutch, deal with it.. do the doors on the sentra actually thwump when u shut them ot is it tinny?
[HR][/HR]​
Nope, even the doors are nice and solid.
Do you push the clutch all the way down when shifting? I don't know about you, but I barely need to put the clutch down 1/4 of it total travel distance to switch gears. Hardly enough to even notice any Marshmellow feel. The only time I ever put it to the floor is to start her up.
1 - 7 of 7 Posts
