1 - 2 of 2 Posts
Hi Dick,
I recently purchased the Real Street Kit for my '96 Jetta with the base suspension. When I unpacked the front struts/springs I noticed that the coil on top of the springs was much smaller than the stock ones. As a result the top of the spring is just resting on the bottom of the spring retainer rather than in the helical slot where the old springs used to sit. Was I sent the VR6 springs by mistake? If so will that make a difference when they are used with the 2.0L spring retainers? The reason I ask is because there has been a rattling noise coming from the driver side front, and I'm curious whether this is the cause of it. Thanks.
1 - 2 of 2 Posts
