ST Suspension has announced the release of their Coilover Suspension kit for the Polo R WRC Street, a 220hp limited production model which has understandably become quite popular with enthusiasts.  Offering lowering of up to 65mm on most Polo models and tuned by the engineers at KW, the kit greatly improves aesthetic while retaining a comfortable ride quality.
Read the full Press Release below.
With its engine power of 220 hp, the VW Polo R WRC Street is superior even to the new Polo GTI; although this one will be launched with a performance update for the 30th anniversary of the Polo G40 in its fourth generation.
Volkswagen-Polo-R-WRC-Street-by-ST-Suspension-362
As one of the few suspension manufacturers ST suspensions already has its new ST X, ST XA and ST XTA coilover kits available for the Polo R WRC Street that is very popular in the performance aftermarket and is already sold out today.
Volkswagen-Polo-R-WRC-Street-by-ST-Suspension-366
While these ST coilover kis allow a continuous lowering of up to 30mm at the already from factory lowered Polo, for the Polo GTI and other models of the Polo 6R-series, a lowering of up to 65mm is possible.
The adjustment of the lowering is made either at the front axle via the ST trapezoid thread of the several times refined and sealed steel strut or at the proven ST rear-axle height adjustment.
Volkswagen-Polo-R-WRC-Street-by-ST-Suspension-364
Without restrictions on the driving dynamics, it is possible to adjust the lowering of the current Polo models between 20 – 50millimeters at the front axle. At the rear, the axle geometry allows a lowering of the body centre of gravity by 40 – 65millimeters. For the special model that is already lower from factory, the ST coilover kits allow an additional lowering of 5 – 30mm.
Enhanced driving dynamics with KW Engineering
The days when a coilover suspension was harder than a conventional suspension kit, are long gone. By using shorter damper housings, the spring travel can even be up to one centimetre longer than at the standard suspension.
Volkswagen-Polo-R-WRC-Street-by-ST-Suspension-363
So despite the lowering, there is enough comfort in everyday life. In addition, the ST coilover kits for the Polo have a suspension setup that was determined in numerous road tests and long-term tests, that provides a more direct handling and better grip at a sporty driving style.
Volkswagen-Polo-R-WRC-Street-by-ST-Suspension-367
While the ST X coilovers have a factory-fixed damper setup, the damping forces of the ST XA and ST XTA can be set more comfortable or tighter.
Volkswagen-Polo-R-WRC-Street-by-ST-Suspension-368
The adjustable aluminium Unibal top mounts for the front axle, are always included in the delivery content of the XTA coilovers. By changing the camber angle, the tires get an optimum contact area when cornering ideal for drivers who want to get the maximum performance for their Polo. For further information please visit the  ST suspensions website.
