I'm not finding the answers to the questions I'm turning over in my head.
First, I have a 2006 GLI with 55k on it, original owner, loved it for the first year, and have tolerated it since. I had an issue a couple weeks ago and finally found a dealership I can trust. They fixed the problem and it seems to run better than it has in two or more years. I'm liking "Helga" again.
Every TSB or recalled component written for the 06 has failed on my car, except for the HPFP cam follower... Go figure:screwy:
Here in Louisiana, it gets hot and humid. Really, it does. For the past couple years, anything over 80 degrees peels away at least 20% or more of my torque. Imagine what 100+ degree does.
Has anyone else's all stock FSI gone "dead" like this over time with no detectable mechanical problem? Under 70 degrees is a world of difference, but still not up to snuff. Well, as I said before it is doing better than the past couple years, but...
Now to my intended question:
1. What about APR stage 1? I guess most on this board are chipped. Did you chip because you were feeling underwhelmed or was the engine seeming to loose its mojo?
2. If your engine was losing its manhood due to normal wear (can this be considered normal?) what did stage one chip do for you? I'm confident Southwest VW of Lafayette, LA was thorough. They did get it running much better than before, but said everything else is in normal parameters. So, having said that...
3. What can I expect from the stage 1 chip? Sure, I read the claims and had a couple email sessions with them (who I value very much already) but I get the impression their stage 1 claims are with other mods installed.
4. How many APR chip users out there have had their chip detected by the dealer? I'm thinking NOTHING is bulletproof and eventually VAG COM will be able to detect it. So, what can they fault me with if I'm ever detected?
5 Finally, in you honest opinion, what are the cons of the stage 1? I've read many pros, but don't really know if I'll have like success. I guess if I can't find enough cons, maybe I'll finally take the plunge. In other words, make my mind up for me!:laugh:
