1 - 4 of 4 Posts
Discussion Starter #1
Doing a rod swap on my car currently and I'm going to do a clutch as well. What stage clutch should I get, 2 or 3? I do 80% highway driving and the rest is local. I do go to the drag strip occasionally. If the clutch pedal is stiff I don't mind because I'm used to a cable clutch from my old 5.0. I just don't want a clutch that's overkill for the car.
Thanks.
Re: Stage 2 or 3 for 02M?? (GLiMKIV)
Here are a few to look at.
$639.95 Stage 1 Sachs Clutch Kit with 16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM OE Sachs Pressure Plate,Sachs Unsprung Disc,6 flywheel & 6 pressure plate bolts, OE release bearing.
STAGE 1 KIT
$699.95 Stage 1+ CLUTCH KIT with 16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM OE LUK Pressure Plate,Clutchnet Sprung Hub Full face Organic Disc,6 flywheel & 6 pressure plate bolts, OE release bearing.
STAGE 1+ KIT
$894.99 Clutchnet Stage 2 CLUTCH KIT 16.5lb flywheel FST Single mass steel billet 16.5 pound 240MM flywheel, 240MM CLUTCHNET 2,200lb modified Pressure Plate,Clutchnet Full face Disc,flywheel & pressure plate bolts, OE release bearing.
CLUTCHNET STAGE 2 KIT
$894.95 Clutchnet Stage 3 CLUTCH KIT 16.5lb flywheel FST Single mass steel billet 16.5 pound 240MM flywheel, 240MM CLUTCHNET 2,200lb modified Pressure Plate,Clutchnet 6 puck Disc,flywheel & pressure plate bolts, OE release bearing.
CLUTCHNET STAGE 3 KIT
Premium Member
TTq, OBXT, Renegade
Re: Stage 2 or 3 for 02M?? (FourSeasonTuning.com)
Southbend also makes quality clutches, I'd get their kevlar http://****************.com/smile/emthup.gif
Discussion Starter #4
Quote, originally posted by FourSeasonTuning.com »
STAGE 1 KIT
STAGE 1+ KIT
What does the Stage 2 support as far as HP and TRQ?
1 - 4 of 4 Posts
