1 - 12 of 12 Posts
http://www.mydubmedia.com/gallery/albums/Keep5/Mani_005.thumbIMG]
I started with 40. Should I do a little more? Or is it okay to move on to 80?
[IMG] [URL="http://www.mydubmedia.com/gallery/albums/Keep5/Mani_006.sized"]http://www.mydubmedia.com/gall...sized[/URL]. IMG]
You can see more of the rough spots here. All in all it's going pretty smooth so far.
More updates later.
[I]Modified by redsox at 11:11 PM 2-16-2004[/I]
Banned
Re: Started the mani last night......what do you think? (redsox)
Fixed the pics for ya.
Quote, originally posted by redsox »
More updates later.
Lets try this again........
Discussion Starter · #4 ·
Re: Started the mani last night......what do you think? (SalemNHGreenGolf)
HOLY CRAP. that was fast. What'd I do wrong?? I know, I know, I've been a member over a year I should know how to post pics, right??
im actually in the process of doing my manifold and i used 80 grit to start and then moved on from there. I also did as much as i could with a 5inch orbital sander with 300 grit on it and it made things alot faster.
Banned
Re: Started the mani last night......what do you think? (grnVentoMk3)
I need to pick up an extra mani that I can work on while it's still cold out
You need to go untill all the scratches are gone..then move to the next grit. If you move to fast, you will have to go back when you hit 1000 as these will not come out.....
Sean
2002 EV
Re: (EuroStyle)
keep goin... all the scratches need to be the same at the end of each stage... for example in this pic see how there are still some darker spots? they need to be gone...
...at each stage just make sure all the scratches are consistent and youll be golden http://****************.com/smile/emthup.gif
Discussion Starter · #10 ·
Re: (volcomvw)
Quote, originally posted by volcomvw »
Those bastards are pretty deep. I'm kinda worried about the amount of material I'll have to take off, to get them out.
Thanks for the replies, I guess i will continue with 40 grit till all blemishes are gone.
BTW, can anyone reccomend a technique when I get close to the flange??
Discussion Starter · #12 ·
Re: (theflygtiguy)
Quote, originally posted by theflygtiguy »
you have a loooooooonnnnnnggggg way to go
good luck http://****************.com/smile/emthup.gif
Hahaha, yeah I know, by the time I finish I probably won't even have the car anymore.....
1 - 12 of 12 Posts
