For some time, I've had starting issues with my '81 S. Symptoms:
Cold start:
Cranks, fires, dies almost immediately unless you feather the throttle. After 30-ish seconds it may hold an idle, but the idle will then continue to drop from a normal 950 rpm to 400-500. Once the car reaches normal operating temp, it idles just fine.
Warm start:
Cranks, fires, dies almost immediately like the cold start unless feathering the throttle. It will then go through a period of a minute or so that it just won't idle, but then after that all is well.
I ran all the fuel pressure tests on it today (per the Bosch fuel injection book) and everything checks out as perfectly normal. The only other thing I've done is replace the aux. air regulator with a used one of unknown condition.
Anybody have some good solid ideas on where I should go from here? (I am *not* Megasquirting this car, it is staying stock, including the doggy 1.7 engine.)
Cold start:
Warm start:
