hey everyone, i am having some troubles starting my car, a few weeks ago my megasquirt was resetting on me because i had crimped all of my wires instead of properly soldering them. so i went back through my harness and soldered it all. now for some reason my car will not start at all. it cranks for a few seconds and the cranking slows down until it doesnt crank anymore. i have attached a couple logs showing what the car does, for some reason the voltage drops severely while cranking, from 12.5 volts to 7.8 volts. I have tried 4 different batteries, i was using a Werker (deep cycle wheel chair battery) which worked great, i traded that one in for a brand new one and still the same result, i used a standard car battery that is in the car i am currently driving (pontiac fiero) and nothing. and then i just traded my wheelchair battery in for a brand new car battery, only to find the same result. the engine will turn over twice or three times but slow down until it wont turn anymore. I am completely stumped. I have a MS1 extra v3 board with wasted spark running the hi res10g code but will be reflashing it tomorrow back to the 029y4 code. i am baffled as to what is going on. it doesnt seem to be a problem with ms but the charging system its self. i just bought a brand new starter as well recently cleaned and gapped my plugs, i get power to everywhere that power needs to be, injectors, main relay starter, and ECU. Obviously something is robbing the cranking power but i dont see what. if i could get some help that would be great. The engine is a 1.8t AWP (2004 Jetta engine) running 42 lb (440 cc) injectors.
Thanks
Justin
PS i am not sure how to attach files it tells me in a box below this one that i do not have permission to so post your emails if you are interested in seeing the log and msq
Thanks
Justin
