Quote, originally posted by Passat_BR » |
On the other hand a bad coolant temperature sensor will cause rough starts. It sends the temperature to the ECU, so it can adjust FUEL/AIR mix. Is the car flooding when you crank the engine (i.e. Do you smell gas when cranking the engine ?) If you do, the way to start a flooded car is to step the gas pedal to the floor (so the fuel injectors will actually block) and then turn the key for about 10seconds... the engine will eventually start. Modified by Passat_BR at 9:10 PM 11-28-2006 |
Quote, originally posted by ClscFlm7 » |
I am not a car savvy person -- how can I know if its something as grave as the alternator -- or one of the other things mentioned above without having to pay the dealer $$$? Any advice very gladly taken. Thanks. |
