Re: Starting problems first time for the day (sparkknock)
try starting in the dark while someone is spraying water and look to see if it is arcing at all this is a common problem that people often mistake for fuel stuff spray wires ignition coil and all if it is arcing replacing it should fix problem for not a ton of $$$
