1 - 3 of 3 Posts
Is it normal that when i have my A/C maxed out, my steering wheel shakes a bit at idle ? anyone else with this problem ?
Re: Steering Wheel !!!! (SoccerGTI)
AC on full blast in Canada?!? Bet you are glad that you don’t live in Florida. Just kidding as I know that you can see 100°+ days just like we do.
Most likely, what is happening is that at idle, w/ the AC on, the rpm is dropping just enough to cause the motor to shake. Not much of a drop in rpm is required. To verify, look at the rpm with the AC off as well as with it on. Try bringing up the rpm a bit and the shake should go away.
it does go away, but does this happen to everyone ?
btw it is very hotttttt here in montreal, no complaints when your driving your 20th in that type of weather
1 - 3 of 3 Posts
