1 - 20 of 80 Posts
Holy cow this car is gorgeous!!!!
From Audiworld.com, http://www.audiworld.com/news/02/rs6/
quote:[HR][/HR]
The eight-cylinder V-engine with a displacement of 4.2 litres has been specially developed for the Audi RS 6. It achieves a permanent maximum power output of 331 kW (450 bhp) between 5700 and 6400 rpm. Its peak torque of 560 Newton-metres is available across an extremely wide range of engine speeds, from 1950 to 5600 rpm.
Development work on the V8 biturbo engine, which has five valves per cylinder unit, intake camshafts with hydraulic adjustment and two-stage intake manifolds, was spearheaded by quattro GmbH in close collaboration with AUDI AG's engine development department at Neckarsulm.
Most of the impressive power gain is attributable to the two turbochargers, the efficiency of which is further enhanced by two pressure-loss optimised intercoolers. There is one turbocharger per bank of cylinders. The admission and exhaust ports have been modified in line with the engine's higher performance, and the cross-section of the air ducts enlarged at both the intake and thrust side.
The adapted engine management is another key aspect of the RS 6 engine's efficiency. The Motronic ME 7.1.1 operates with boost pressure, knock and exhaust-gas temperature control. quattro GmbH has developed a dual-branch exhaust system with backpressure-optimised middle and rear silencers, larger-section pipes, and primary and main catalytic converters with a metal base. The RS 6 thus satisfies the EU3 emission standard.
To distribute the weight more effectively throughout the vehicle, the battery has been moved further back, into the spare wheel's recess. The upper section of the air cleaner is made from a carbon fibre composite material; together with a further carbon fibre cover over the front section of the engine compartment, it gives the engine a striking appearance.
In keeping with the car's high performance, quattro GmbH has developed a completely new brake system for the RS 6. Large brake discs of a composite design have been fitted on both the front and rear wheels. This technology, which originated in the world of motor sport, involves fixing a cast friction ring to an aluminium brake-disc chamber by means of 14 pins. This "floating" arrangement improves the stability of the brake discs, particularly when exposed to extreme loads and at high operating temperatures.
The ventilated, perforated disc brakes have a diameter of 365 millimetres at the front, and 335 millimetres at the rear. The grip is achieved by means of eight-piston brake callipers at the front and single-piston floating callipers at the rear. The parameters of the ABS system and the electronic brake-force distribution system have been specifically redefined for the high-performance brake system. [HR][/HR]​
90 Corrado, 97 B4 TDI, '10 CC 4 MO
Re: Step aside M5, the RS6 is the new king of the sport sedan hill... (CanuckPal)
I could live with the Auto. I would just like the chance to even be able to purchase it. (After hitting the lottery, of course)
quote:[HR][/HR]I'll still take the M5. Sorry, I'm a manual transmission snob.
[HR][/HR]​
No manual for RS6? http://****************.com/smile/emthdown.gif
[HR][/HR]​
Exactly.
Re: Step aside M5, the RS6 is the new king of the sport sedan hill... (zerind)
Agreed.. that car is something else.. tiptronic or no, it'll still straight up move like nobody's business. I mean.. seriously.. what happens when your car has AWD and produces 412 ft-lbs. of torque at 1900 rpm? I guess the answer to that is 0-100km in 4.9seconds. I'm kinda curious what the boost/size on the turbos is.. imagine upping the boost on this thing..
Re: Step aside M5, the RS6 is the new king of the sport sedan hill... (cougar)
The RS4 did 0-60 in 4.7 seconds and that was with 380hp. Why the hell isn't Audi putting out a 6 speed with this car?
Take the RS6 with a 6 speed and you should see 0-60 in 4.5 seconds easily.
[Modified by Jeff Andrews, 9:05 AM 2-13-2002]
Re: Step aside M5, the RS6 is the new king of the sport sedan hill... (Jeff Andrews)
Where are all those non-discplacement gurus???? Wat to up the anit Audi! http://****************.com/smile/emthup.gif Nice car. Me I will take the not so obvious choice MG XZT! Yes please, and its faster then both the M5 or this RS6, looks the part as well!
Re: Step aside M5, the RS6 is the new king of the sport sedan hill... (A4Jetta)
quote:[HR][/HR]Its an auto doesn't mean its slow, look at C32 and E55. I will take a RS6 over M5 anytime, anyday and anywhere.[HR][/HR]​
Not me...there's no substitute for manual driving....especially when it comes to pure performance. http://****************.com/smile/emthup.gif
· Banned
Re: Step aside M5, the RS6 is the new king of the sport sedan hill... (Silver Ghost)
It simply cannot be the ultimate performance sedan without a manual transmission. Sorry. Being a sports sedan means involving the driver in the act of, you know, driving. Even my Jetta, which no one here would put in that league, offers a choice.
BMW M5. Hail to the King, baby.
Hey Audi! Come back when you have a REAL sports sedan. http://****************.com/smile/emthdown.gif
I don't drive a manual for the performance, I drive it because it's so damn fun!
Re: Step aside M5, the RS6 is the new king of the sport sedan hill... (mtrainVR6)
quote:[HR][/HR]BMW M5. Hail to the King, baby.
Hey Audi! Come back when you have a REAL sports sedan. [HR][/HR]​
Exactly, at this price point and performance level, I will take the M5 with the manual transmission. http://****************.com/smile/emthup.gif
G
Re: Step aside M5, the RS6 is the new king of the sport sedan hill... (Obelix)
I suspect that the bulk of buyers in the "executive jet" segment prefer having an automatic to a manual. Of all the cars in this class (M5, S-Type R, XJR, E55, S55, RS6), the M5 is the only one that's ever offered a manual transmission.
Most of the people I see at my dealer with XJR's are women in their late 40's/early 50's!
1 - 20 of 80 Posts
