There are two vertical holes that about 1/2 inch from the edge on both side. You may try something hard enough to insert into about 1/2 inch. The deck will come out if you success.
Push back is easy. Good luck.
If you don't have the keys, which the dealer should have given you at the time of purchase, people have had success using the metal portions of hanging file folders. The notch at the end of that metal strip is similar to the notch in the keys.
btw: these keys we're referring to aren't anything special. their just little slim pieces of metal with a notch in one end.
Thanks for the info. Now that brings up my next question. I just purchased this car used from the original owner, and I'm not even sure where to look for the stereo removal keys. Are they typically in that black owner's manual pouch thingy?
Thanks
They're small little thingies that, unfortunately, can get lost very easily. They'd probably be in a mini plastic bag. See if a local dealer will give you a pair. Otherwise, the hanging file folder metal strips really do work with little trouble.
Don't worry about it. I didn't find mine either and last night I tried the hanging file folder trick. It works perfectly. http://****************.com/smile/emthup.gif
