Re: Stiff Stock Height or Plus height Springs (bshore3rd)
If you want a set of stiffer, higher performance springs that won't significantly drop the car, I'd recommend that Shines should be your best bet.
Other second choices would be Sofsports or H&R OE Sports. Both are progressive, and drop the car <1".
I'm not sure who would have raising springs, as most of the automotive spring aftermarket is dedicated to "dropping" cars. The truck aftermarket would raise the vehicle, but I'd have no idea where to even start to find a set of springs that would work.
Maybe a set from a comparable, but heavier VW, like a Passat?
