1 - 6 of 6 Posts
I am currently hooking up some golf lights on on jetta, I know the harnesses are different, what wires go where if I was to use female clip and to just plug them on the tabs? Anyone know, on the Jetta there are only 3 wires,(1clip) on the golf there are 2sets of wires and (2clips) anyone have a clue?
Re: Stock Golf lights on a Jetta, wiring?? (veedubbinNy)
check out the color of the wires
there should be a common ground between both harnesses
splice these two into your common ground off the jetta plug (brown I think)
after that you only have to figure out which is high and which is low
you can do that with a multi meter or test light
Re: Stock Golf lights on a Jetta, wiring?? (TeamDynasty95JettaGL)
I do not have the GTI harness I have only my jetta harness, I cannot use my buddies harness due to him having to use it. I only have three wires, and there are 4 tinny male clips and (2harnesses for each light) do I only need one ground got each light?
Discussion Starter · #6 ·
On the MkIV lights there is only one harness hook up???? What harness is this called, I could probably pick one up, I just need to know what it is called on the MkIV lights. Any help would be appreciated, if anyone knows what the harness is called.
1 - 6 of 6 Posts
