Hello Mk7 Golf R owners,
I'm gathering some information on MK7 Golf R owners with a manual transmission and have experienced any issues with the transmission, shifting, clutch slippage, flywheel, pressure plate components that a dealership has diagnosed and would not replace/ repair under the manufacture powertrain warranty.
I have a 2017 MK7 R with the manual transmission, the R has 22,000 mile on it and I have had to take it back to VW service for sporadic difficulty engaging reverse, 1st and 2nd gear. There has been a few times of what seems like excessive drivetrain noise when shifting from 1st to 2nd gear. In every instance the VW service department could not recreate the problem. My most recent problem with clutch slippage was determined to be a problem and VW took out the trans and found hot spots on flywheel, pressure plate,and clutch. VW told me it would not be covered and the driver of the car has abused the car and had bad driving habits. This accusation is so far from the truth, I have owned many VW's and other cars with standard trans and never replace a clutch due to failure or "abuse".
I called VW of America and they created a case and then they contact my servicing VW dealership for their diagnosis. They shared what they found with VW of America and the dealer would not replace any clutch part or component due to abuse. VW of America called me with the dealerships decision and I was told because this is an independent dealership, VW of America can't force them to honor the warranty due to their findings of neglect.
An additional note, I asked my case worker at VW of America if they could compile data to identify the number of issues with the clutch/ pressure plate/ flywheel while inside the manufacture warranty. I also asked if she could find out when the last research and development was conducted on the Golf R clutch and components? I was told that the information was available but for internal use and would not be shared.
Moving forward, I ask that you post a response only if you had issues with the factory stock car and stage 1 modification. The drivetrain components should be designed to handle a certain % over stock performance expectation.
I plan to compile the issues and take the numbers to VW of America.
I thank those MK7 R owners who provide info on their drivetrain issues.
Thank you,
Sam
Thank you,
Sam
