pb blaster and an air hammer, you can also pop a chisel into the slot of the spindle. there is a specialty tool to make things easier but the last thing i want to do is buy a tool ill use once in a blue moon. the other alternative is to pull the axle bolt and pull the strut with the spindle assembly. you will need new axles bolts and a torque wrench with some muslce if you go that route. enjoy
