1 - 3 of 3 Posts
So I have a v-checker pro scan tool and I am trying to diagnose my cars sudden loss of power on acceleration. It seems to happen mostly when accelerating from stopped and usually right after I shift to 2nd. I have been looking at measuring block 115 to see what my boost readings are like and I have seen that the actual boost is showing higher than the specified boost. When my boost gauge shows 0 PSI, v-checker shows actual boost as around 1300 mbar. The v-checker also never shows a value below 1000 mbar for actual boost even when the car is idling. Can anyone shed some light?
1000mbar = 1.0bar = atmosphere...
I hope you wouldn't drop below 1 bar to much, though I hear space is nice this time of year...
1.3bar = 18 psi - 14psi ( 1 bar ) = ~4psi
Sounds like your in limp.
What about vacuum? For example, when I'm idling my boost gauge shows around 23 inHg, which translates roughly to 300 mbar. I've seen the specified boost drop below 1000 mbar a few times, but never the actual. So the question now is, does the MAP sensor only provide positive pressure readings? The v-checker is showing about 1300mbar or 3-4psi when my gauge shows 0 psi. I'm wondering if its a problem with a sensor or with the v-checker pro. Then at max boost ~1600mbar the actual and specified readings match up and are pretty close to what my boost gauge shows ~8-9 PSI.
I've seen a lot of posts about people having leaks and seeing higher specified boost vs actual boost, but my problem seems to be the opposite. At least for the lower end.
1 - 3 of 3 Posts
