Hey Vortexers. The dealer gave a print-out of some engine fault codes on a 2000 Golf GL. The check engine light was on, but still seemed to run ok. Any ideas?
1. 16556 P0172 035. System too rich, Bank 1.
2. 17633 P1226 035. Cyl 1 injector circut low.
3. 17634 P1226 035. Cyl 2 injector circut low.
4. 17635 P1227 035. Cyl 3 injector circut low.
5. 17636 p1228 035. Cyl 4 injector circut low.
6. 17833 P1425 035. EVAP can purge regulator valve - N80 - short circut to ground.
7. 17880 P1472 035. EVAP Emission control LPD circut. Short circut to ground.
8. 17536 P1128 035. Bank 1 mixture adaption ( mult.) system too lean.
Is ANY of this seem legit on a seeminly good running car? Is any of this 'owner-fixable' ? Where should I start looking to remedy these things.
I appreciate ANY and ALL responses that can help.
Thanks.
Thanks.
