Re: Strange vibrations... CV Joints?? HELP? (monsterjetta)
Usually, CV Joints will get loud and start making a knocking noise on turns before they cause a major vibration. At least on other cars I've owned. Not sure on VWs.
Is you car significantly lowered? If so, maybe the drive shaft has a slight bend from hitting the front swaybar.
Just a thought:
I had a simular problem with a Honda I owned. Some days the tires were in balance, until I accelerated. Other days they were fine. Some days they were bad all the time. I must have had all the wheels balanced 4 times, before replacing the tires. When the tires were off the rim, we noticed they were filled with a about a cup of water each.
Apparently, some service stations have problems with water getting into their air hose, so whenever I put air in a tire, a little water got in each time. Now I check the air hose every time before I connect it to the valve stem. Also, beware of those Fix-a-Flat air cans, they will do the same thing.
Modified by Y2KVR6GTI at 5:00 PM 7-1-2003
