Striker pin alignment?
524 Views 6 Replies 4 Participants Last post by  psmiech
Can anyone post pics of the front door striker pins along with the marks on the door frame? I have a funny feeling that mine are misaligned, which causes clicking noises. I'm thinking that the door doesn't make a good seal with the seals. It was raining today, and the clicking noises went away, so I think it's coming from the door seals, and not the locks as I originally thought.
1 - 7 of 7 Posts
Re: Striker pin alignment? (BikeBoy24)
describe your clicking? Is it creaking, have you tried lubricating the striker pin and latch?
Re: Striker pin alignment? (wlombardi)
Well, it's more of a clicking/rattling noise. Yup, I've lubed everything, many times. I even tried the electrical tape thing. I definitly think it's something to do with the door seals.
Try this:
http://forums.vwvortex.com/zerothread?id=165030&postid=1325825#1325825
Do NOT adjust the striker plate. You will end up like me with a misaligned door and it will never be the same. Lubricate your weather stripping....
Re: Striker pin alignment? (adg44)
I think the dealer already tried to adjust the striker pin before. It actually made it WORSE. The alignment of the door is alright though.
try spraying some silicone lube around the hinges.... I had a clicking noise... and the lube took care of it... got it from Crappy Tire for $5.00
1 - 7 of 7 Posts
