1 - 4 of 4 Posts
i wanna keep as much of the stock system as possible but i would like to add on subs and build a custom fiberglass box. can u use the stock amp or should i get anouther amp. If i do that what do i do with the current subs? are they still usable?
Re: sub amp? (vw121)
Buy another amp for the box...and keep the stock for the speakers. http://****************.com/smile/emthup.gif
Your monsoon amp won't push a decent sub. You'll definitely need a new amp. Check the car audio forum for install instructions with the stock system.
Re: (GTI20thAEinDE)
you can easily add a subwoofer to your monsoon system. you have a remote turn on lead wire that is blue that plugs into the back of your monsoon headunit. you can tap into that to run a new turnon lead to your new amplifier. after that all you need is your power, ground, and rca's. you will definately need another amp though!! if you have any questions about this i do this for a living so email me and i'll be more than happy to answer any questions you may have.
1 - 4 of 4 Posts
