1 - 7 of 7 Posts
I have a 1988 cabriolet with CSI it's sucking oil into the air filter box and into the throttle body is there a reason for this...I'm going to check compression readings this week.
It's pulling enough oil into the air box to pour out of the side...air filter drips oil when you pick it up. Seems to be way to much oil to be a normal operation of the PCV.
Re: sucking oil into intake (1988VWcabriolet)
i have a 88 golf with digi that has hella oil in the intake tube , that the same thing i think i need a knew pvc valve then
1 - 7 of 7 Posts
