1 - 2 of 2 Posts
After re-oiling my k&n drop-in today (it had about 12k miles on it) and doing a little bit of sanding to the upper section of the airbox, my dv has gone from silent to (relatively) bov-like, making noise when I come off-throttle in every gear except first. Is it normal for this much of a change to happen, or could I have under/over oiled the filter?
Re: sudden dv noise... (1.8fla)
DV valve is common to lose vacuum and make noises as you described. It is covered under warranty being that your car is an 03.
1 - 2 of 2 Posts
