Re: Suggestion for Upsolute... (SlvrBllt)
The only models affected are the 2002 Jetta/Golf, and then only 4 or 5 guys running version 5. The only difference in Version 6 is in the boost peak, overall Hp will remain the same. You have several options, Go to version 6, it is the only one we will use from now on anyway. Adjust your N75 , or replace it. Several have adjusted it, one has broken his, replaced it and is running just fine. Whereas he was surging before, Before some other tuners tell you that proper R&D was not done, let me explain that when a file is done and we see 2 or 3 cars running well with it, it is considered releaseable. If one car develops some problem we feel it's limited to that car, if I see two unrelated cars experiencing the same problem, we act and a new file version is produced to correct it. We did this, and produced version 6. Jim told a client that 6 was not as strond as 5, big mistake, Jim did not clarify his statement, because several have chipped and demanded ver 5. The rep obliged, that will not happen again. We try to produce a file that works on 100% of the cars out there. If a few are off, we will correct for the lowest common denominator. Several have posted that they have switched and it eliminated the problem, and the file does not feel any weaker. That said, Even with Version 6 chances are your car will be better if you had a proper adjustment on N75.
