1 - 20 of 63 Posts
Disclaimer: All work done is at your own risk. I hold no responsibility to anyone for messing up their car, cutting your arm off, angry wives etc... Results may vary if you use different substitutes for the items listed below.
All the items listed below can be bought at you local Home Depot. Total Cost is about $12.00
The Goods:
Flat 1/8” Thick ¾” x 36” Aluminum
3M double-sided tape
small hacksaw
black paint & primer (not painted in the pictures so you could see it)
razor blade
ruler or tape measure
Let’s Get Started…..
Read the entire instructions and look at your car. If you don’t understand something ASK!
Measure the aluminum bar 20” and mark then cut with hacksaw
Primer and or Paint the 20” aluminum bar black (again the one pictured is not painted so you can see it)
Apply 3M double-sided tape to one side of the painted aluminum piece and trim the excess tape off with a razor.
Installation…Now you can get as anal as you want to measure this too make sure it is in the center of the wind deflector. All you need to do is make sure it’s centered depending on your eyesight you can eyeball it that is what I did. A) I was testing this B)Since it is going to be painted black is anyone really going to notice it? No
The second part of this is getting it to line up with the back edge of the air deflector.
Go out to your car open the sunroof all the way and standing at the side of your car push the air deflector down. Notice where the back of the air deflector sits in front of the lip
In the below picture the air deflector is in the down position as if the sunroof was closed
I removed the protective plastic off of the tape and carefully put the aluminum bar down in the deflector track and lined it up straight with the back edge of the air deflector and then pushed the deflector down to make it stick to the bottom. I then ran my finger along the bottom of the aluminum piece and pressed up to make sure the tape was sticking to bottom of the air deflector.
I tested it to make sure the aluminum bar would not cause the deflector to push up on the sunroof when closed or interfere with the operation of the glass closing. I didn’t have any problems but you should check also.
Your Done!
I have been running this for about two weeks and drove about 300 miles with the sunroof open going max 95mph and no problems.
Comments, Suggestions are welcome. Hope this helps! If I screwed something up let me know and I'll fix it.
Modified by 20grit_timber at 6:33 PM 5-16-2006
Modified by 20grit_timber at 6:41 PM 5-16-2006
Re: (jcstomper)
My sunroof seems to be fine, i havent had any unnecessary levels of wind noise... You guys should here the BMW 530xi that my dad has, that is the loudest most annoying sunroof I have ever heard.
Re: (cgvalant)
I have a cheaper fix...roll down your windows LIKE A MAN or don't open up the sunroof so far. There's a reason it doesn't open all the way without your hand on the switch.
OR......here's an idea........
get a convertible!
Discussion Starter · #7 ·
Re: (VTECeateR)
thanks andre i'm bleeding from my eyes now. hold on i'm going to shove a hot poker up my ... now. thanks oh now my arms just fell off damn. you know your like the hand from the monsters tv show you show up and poke someone in the anus and run away and we can never catch you or find you. http://****************.com/smile/emthup.gif
Re: (20grit_timber)
Quote, originally posted by 20grit_timber »
It sounds like english, but I didn't understand a word you said. It's like he's trying to speak to me!
Thanks for the write-up. I'll give it a try on my car this weekend.
Re: (VTECeateR)
Quote, originally posted by VTECeateR »
The first pic of this car I like......I think tuned (modded-for you new guys), it will look really good.
So how does it work? Sunroof thingy?
Re: (20grit_timber)
That quote actually scared me.
did you mean about the Eos pic?
Re: Sunroof Fix for Buffeting Air Deflectors (20grit_timber)
Hi Timber,
How does this work? Does it strengthen the deflector to minimize shake, or does it add weight for something?
Thanks,
Ian.
Re: (20grit_timber)
Must be some strange language that twins teach each others (fans of SNL will remember this from the Keth Richards/Mick Jagger skit)
Real men don't buy cars with sunroofs (ducks and runs for cover)
I'm sure there is a Chuck Norris joke in there somewhere.
Sorry for the thread hijack. EXCELLENT Write up!!! http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
Re: (VTECeateR)
Volkswagen has a fix for the sunroof problem... they fixed mine the same exact way! They didn't call it double sided tape they tried to go big and call it special double sided noise reduction tape, or something like that!
Banned
Re: (electricme)
Quote, originally posted by electricme »
Sorry, but that's pathetic... VW's fixes are pissing me off. Just like the "anti-rattle kit" they supposedly installed on my dash vent... their kit was breaking two tabs off the air vent, and wrapping the temp sensor in scotch tape (and it didn't even end the rattle)
They should engineer this stuff properly to begin with so we don't have to do these DIY hack fixes.
Great write-up, thx http://****************.com/smile/emthup.gif
Have to do this... the buffeting on the GTI is way worse than my previous mk4 Jetta.
Discussion Starter · #18 ·
Re: Sunroof Fix for Buffeting Air Deflectors (kornjd)
Quote, originally posted by kornjd »
Hi Timber,
Thanks,
Ian.
It just adds strength to the air deflector.
Thanks.
1 - 20 of 63 Posts
