How much caster is too much? My Jetta has +6.6 degrees left front, +6.0 degrees right front. Car pulls to the right (will drive up over the crown of the road on a freeway by itself).
Toe is nearly perfect, camber is fine, tires have only 6,000 miles on them and psi is even on both sides. Two alignments done in the past 6,000 miles, shop says caster is not adjustable. Tires do NOT show any uneven wear. All front suspension bushings + tie rod ends are less than a year old.
Could the caster be causing the pull to the right, and is it adjustable on these cars?
