Finally had a few minutes to check stuff out on the car change some things.
Got the 215s on up front 235s in the rear. The rear is nice and sticky but still break loose under wot. 1st and 2nd. Not as bad as the 205/40/17s. That was like driving in the snow.
SLIDEWAYZ It's so much ****ing fun. And It's nice to drive fast again and not rub.
Switched plugs to the colder heat range, car loves it! Thought it was just heat soak I was experiencing,
But I switched plugs and car peaks at 8psi boost feels smoother.
I did order Stern density line diff carrier bushings yesterday from ApTuning. Went with stern instead of 034s product due to the fact I run a stern snub mount and trans mounts.
Get rid of the clunk I keep getting on smokey launches.
Still gotta do control arm kit had set out to do that on Sunday and wound up changing suspension and doing plugs.
