Re: Supertech valves... (VWralley)
Hey fox,The supertech Valves you speak of run what is called an "undercut"stem like rally is talking about, the standard on a 16v is 7mm the supertech intakes are undercut by one millimeter below where the valve protrudes into the port under the guide.Less surface area inside the port is better being it yields less frictional losses for the air entering the combustion chamber.they are also over-sized by .5mm to allow for more air into the combustion chamber.
I currently run these valves on my solid head they are also nitrate coated for better wear and heat transfer.
Your horse power to tq loss is dependent on how much overlap,duration, and the base center in which the the cams have been measured off of,not the actual amount of port work or the size of the valve with larger cams you have more overlap.Because of the duration in which the valves are open in the rotation cycle, it leaves time for incoming air to escape out either the exhaust or intakes on the compression cycle of the bottom end.depending on how the cams were built and the ones you choose could effect either TQ or HP .
The best way to look @ port and head specifics is kind like this, Imagine trying to breath through a straw...pretty hard.now breath through a 2" tube much easier your head act's as the mouth and lips of the motor and the air passing through it should have the least amount of resistance making it easier "to breath".
Farrea also makes good valve but they are more money if you want to go completely nuts they now also offer hollow stemmed race valves with a hardend tip where the lifter contact's them.they are lighter which is less weight off of the reciprocating mass of the valve train which could account for more power.
If you want to get either of these 3 types of valves hit me up I get a smoking deal on them.
Modified by X K R O M X at 4:30 PM 10-31-2006
Modified by X K R O M X at 4:32 PM 10-31-2006
