1 - 2 of 2 Posts
I recently put on some H&R sport spring with Tokico HP struts and my suspension is making sounds when i go over bumps or uneven pavement and when i turn my wheel...can anyone give me any ideas as to what I can do to fix this problem?
Re: Suspension is making sounds....PLEASE HELP (VDUBPKP113)
the bottom of your front spring(s) are probably not set against the perch - notch on strut. When you go over a bump, the spring slides and hits the perch...possible cause.
1 - 2 of 2 Posts
