I've got a MKIV VR6 Jetta w/Progress Sport Springs, Bilstein Shocks/Struts and everything was great. I installed the 18x8 Oettinger RE's w/ 225/40/18 Khumo Ecsta's and now when I hit a decent bump the right tire rubs the fender and makes an awful noise.
There is no damage to the fender but over the past couple of months a lot of build up of what I'm assuming is rubber on the inner lip of the fender and I have noticed a small ring on the tire where it is rubbing. Trying to find a solution before it gets worse.
My question is what is the best solution for this? I haven't heard of anyone else having any troubles with the 18x8 rim setup.
My front driver side measurement from the ground to the fender lip is 24 13/16" and from the passenger side is 24 7/16". Allmost 1/2" difference in drop on each side. Is this normal? Is the VR6 engine heavier on the passenger side which may be causing that spring to compress more or is it possible that my suspension needs to be replaced. I only have around 35-40k on my suspension setup (Bilstein's shock struts & Progress sport springs) Any help will be appreciated!! Thanks
I'll try to post a pic. It's not the side of the car where the rubbing occurs but will give you an idea of how it looks.
