1 - 5 of 5 Posts
Hi Vortexers. I have a switch on the fuel rail, near cylinder no1, that has 1 blade connection for a wire. I can't find a wire that would hook to it.
Anybody know what this is? My car is a US model, 5speed and A/C. TIA.
Re: Switch on fuel rail unhooked. What is it? (DONSFLRADO)
Hello,
Engine cooling fan temp switch...after run cooling when engine off and hot enough.
It also start fuel pump for after run fuel circulate...
Re: Switch on fuel rail unhooked. What is it? (mha)
[HR][/HR]​
exactly like he says !
the starting of the fuel pump is to avoid Vapor Lock
Re: Switch on fuel rail unhooked. What is it? (JRG60)
Does a good job cooling down your car (keeping the radiator fan on) and running your battery dead
Which is probably why someone removed it.
It does not cost much to replace, but they new one will have a yellow top this time......works just fine. http://****************.com/smile/emthup.gif
1 - 5 of 5 Posts
