Hi there guys,
Just swapped my 79 Rocco with a 16v 9A bloc, ABF cams and R1 Carbs. Standard electronic ignition that i had already in the car, with a vacuum distributor.
Jets are 180mm Main, 50 Idle.
The car started right up, no problems there. But it is really smoking black. Not even exagerating, you can't stay behind the car without suffocating. And when in a Red Light, well..... a nightmare for those how are behind me :facepalm:
The head was done with new seals and valves, the bottom end is stock, nothing done to it, it has 180k kms (112k miles)
Since the carbs are putting more gas in, do i need to go with another oil than the one stock for this engine?
Now i'm running with the 10W40. Searched all of this topic for oil posts, but found nothing clear and precise, to what people have been running with a similar set up.
Should i try another oil? Do the 16v engines accept 20w50 oil?
Or i have no choice and do the bottom end, piston rings, etc?
pic of the beast
