Thank's guys for the replys!
So to try and answer all the questions:
- The pump is a R1 pump, don't know the fuel pressure
- I don't have a AFR/o2 sensor or gauge
- Choke is not hooked up
- The oil doesn't smell a lot like fuel, but it doesn't smell like only oil... i think that there is a bit of fuel in it
- Float level for me is the standard, i just made sure that all 4 where the same. i didn't find an exact information about it, if you have some information about the mesurement that it should have when installed on the 16v, it would be really helpfull
- Idle screw ajustment is at 2 and 1/2 turns
Today i made this:
- Changed the ajustment screw to 1 turn only, absolutely no change, engine starts immediatly and stays at 1k rpm.
- Looked the timing and i have +9/10° degrees of advance.
- Hooked up my gauges for the syncronization of the carburettors, they are all good
- Spark plugs are black and somewhat greassy
The car runs like crazy!! It has tons of power! so she is running right and reving with no problems. But i only made like 10 miles
I'm waiting for 170 jets that should be arriving soon, but don't even know if that will make a difference
Enlighten me please!!
