I’m sure it does, there’s was another cable that came with this setup but I didn’t use it.Do those carbs have a "choke" bar that activates a plunger on each carb? On my Keihins, it wasn't actually a choke in the traditional sense, but it was more like a two step cold starting enrichment circuit. If yours does have it, what happens when you use it?
Not really trying to drill anything out. Just trying to figure out what size jets I should be running. The car these came off of was tuned for 100 octane if I remember right. So I think a 20 pilot might be to much and I’m sure the mains will be to big as wellDo you have a sonic cleaner? If-not, those things are amazing at cleaning up carbs and I highly recommend getting one. Just be careful what cleaner you use, as some stuff can end up being a bit too rough, or leave a weird finish.
For the mains, if you can get a set of fine drill bits you may be able to find a sizing chart that correlates them to a bit diameter. From there, if you are feeling daring you could drill them out.
First of all, clean the carbs (deep clean, i mean DEEP clean), if the carbs was used in a car with similar displacement to yours dont change the jets, simply clean it and try also clean or replace the air filters.Not really trying to drill anything out. Just trying to figure out what size jets I should be running. The car these came off of was tuned for 100 octane if I remember right. So I think a 20 pilot might be to much and I’m sure the mains will be to big as well
Oh they got rebuilt. They where extremely dirty. Car runs now, just high idle and rich currently. Screws are turned out like 3 1/8th, so I’m gonna turn them in a few turns and see if that will bring the idle down and lean it out some.First of all, clean the carbs (deep clean, i mean DEEP clean), if the carbs was used in a car with similar displacement to yours dont change the jets, simply clean it and try also clean or replace the air filters.
Jetting depends on health of your engine so you must experiment with different jet sizes, you can get a mini drill kit (from 0.80 to 2.0 mm in stepf of 0.1 mm), fill the hole of the main jet with solder and drill it, test it, drill again to different sizes once you feels close to the right size, buy the correct jets.
