41 - 60 of 2101 Posts
Discussion Starter #41
Re: (Miami Blue)
My carbs FINALLY came in today!! Yeeeha! I cleaned the outside up real good first thing, there was some grime on em. Tonight ill open them up and clean them some more. I need to find a manual on these things so i can figure out where all the fittings go. Does anyone knoe offhand what goes where?
And my parts that i have gathered so far: My finished flange, choke cable, fuel filter, pressure gauge, and fpr. All i should need now is fuel hose, runners, and silicone hose for attaching carbs to manifold.
For some reasson my camera likes to switch between black and white, and color
.... Oh well!
Modified by Miami Blue at 6:17 PM 11-27-2009
Re: (Miami Blue)
I have to look at my car to see what the one thing is, prolly cap it!
The vent hose, pull the lines off at the carb, turn them to the sky, they are vent ONLY, DO NOT TRY TO PUT FUEL IN THE CARBS USING THEM! I found that out the hard way!
On your pressure gauge, ditch the fitting and go right off the FPR.
Discussion Starter #44
Re: (FROZEN337)
Ha Ha thanks frozen, as always your help is much appreciated! The two things on the top are vents also i figured out. Lots of vents!
I took the AC out of the Caddy the other day, and moved the alternator down to the lower position. It cleared up alot more room than i expected! Next i need to re-route the coolant hose.
Alternator relocation. (Please excuse any ghetto tech you see in the engine compartment, it was not my work. These carbs are my first step to getting everything right and clean in there.)
Before:
After, without the AC that side already looks WAY better
Discussion Starter #46
Re: (Flyingsheep)
The two vents on the top had small air filters on them, so ill replace the broken filter. Im assuming the filters are there for a reason.
The vents on either side ill cap off for now since they are connected. Im going to talk to a Yamaha tech and see if thats vacuum that i can use for a vacuum advance dizzy.
And last of all, the vents with the tubes that connect at the bottom, im going to remove the tubes and point the two T fittings downwards to help keep any dirt or water that may end up there out.
Re: (Miami Blue)
usually the vents reroute to the air box on bikes. id just tap one of the runners for the vacuum dizzy and for your brake booster. the vacuum port on the carbs may not be strong enough to run both dizzy and brake booster unless you arent going to use vacuum assisted brakes...
Discussion Starter #48
Re: (86Franklin)
For the brakes im planning on doing as you said and tapping the runners. Im thinkin that the vacuum on the carbs should do fine for just the dizzy.
Re: (Miami Blue)
sounds good ha. im in the middle of the exact same thing you're doing except im swapping into a cabriolet at the same time.
Discussion Starter #53
Re: (rocco858488)
The only write up on another web site i have found was by the Bogg Brothers of Europe. It is more of a generic write up, not specific to any one engine:
http://www.totalvauxhall.co.uk...7.pdf
There are a few guys on the Vortex doing, or attempting to do this. The guy who has been most helpful is my main man FROZEN (Thanks dude). He has posted on my thread as well as other bike carb threads.
Vortex R1 threads:
http://forums.vwvortex.com/zerothread?id=4241293
http://forums.vwvortex.com/zer...32202
http://forums.vwvortex.com/zer...34217
http://forums.vwvortex.com/zerothread?id=4307309
Not R1 but good info:
http://forums.vwvortex.com/zer...age=1
There are more threads, but those are some of the good ones.
And one more... This one is great for rebuilding the carbs:
http://www.howmotorcycleswork.com/r6/index.htm
Update for the day
This weekend i made up a coolant hose that will give me much more clearance, im pretty happy with it. It will run on the outside of the alternator and then under the tensioning adjustment bracket.
My runner material showed up last night, i got right to work on shaping them. Shaping took some patience, first i used a vice to oval them out and then a cut off saw to cut the angles.... I dropped the flange and runners off to my brother this afternoon, i hope he doesnt put the welding off. Ill have to keep on him
The runners will be cut down to about where the cardboard is after the welding is complete.
My parents supprised me for christmas so i will be flying back to my beautiful home in Northwest Washington
Im going to have to hold off on the installation till New Years weekend.
Discussion Starter #55
Re: (Flyingsheep)
I only have one week off for Christmas so i gotta wait till next friday to fly out. But thankyou! Its going to be so great to be home!
Discussion Starter #56
Re: (Miami Blue)
Throttle Cable time!
I had been looking at different ways to do the throttle cable for a while and this is what i came up with. It is by far the cheapest way to do it. The cable its self i got at the local bike shop for dirt cheap, you will need the fitting on the end for the throttle lever on the carbs, it just so happens that bicycle brake cables work perfectly. For holding the cable on the carbs i ordered the small bicycle brake adjuster from here:
http://www.porkchopbmx.com/Bra...5.htm
Brake cable with round... thing.
Brake adjuster
I cut down the small mount that screws on to the adjuster and put it on first. Then i used the small nut to lock it in place. After the photo was taken i bent the bracket on the carbs over the adjuster a little, that thing isnt going anywhere!
For the cable to be finished, all i have to do now is figure out how to get a hook on the pedal side so that it will go right in to where the OEM cable goes.
Nice. I would like to do this but i'm focused on maintenance right now. Car was beat on pretty bad by previous owner. Maybe in a few months
Discussion Starter #58
Re: (2.0VEDUB)
Got the manifold back, it looks great! It bowed a little from the welding so i bent it back in a vice and then used a belt sander to get it perfect.
I need to pick up some sort of hose to join the mani to the carbs. Dont know if i want to use rubber or step it up and pay extra for silicone hose.
Question for FROZEN: Where did you get the foam air filters for these things? I cant find them anywhere!
Re: (Flyingsheep)
Manifold looks great! Just wondering if you could post sources for: choke cable, fuel filter, pressure gauge, and fpr. Links to websites, brand names, part numbers and prices would be awesome!
