Syncro to Haldex Conversion kit and 02M mount available
UPDATE Oct 08 Haldex GenII Conversion Kits Coming Soon for the MkII/III platform. This new kit will be based on the MkV rear axle setup, means no syncro parts are needed, this kit uses the parts from the latest MkV/TT setup, this kit can also be used without the 4Motion option to install an indendent rear suspension. Kit will be modular based so you an update in stages.
Stay tuned..
PLEASE NOTE: From March 1st 2008 Dutchdub will no longer sell Syncro to Haldex Conversion kits and/or 02M gearbox mounts. These parts will continue to be available through a new company called Dutch Build formerly Schimmel Engineering. Dutch Build is a new company focusing on special parts for the Volkswagen range. I would like to thank all who supported me over the last couple of years were some of my customer became really good friends...Marcel
http://WWW.DUTCHBUILD.COM
Syncro to Haldex Conversion kit available
A combined action of Schimmel Engineering & Dutchdub resulted in a syncro to Haldex conversion kit. The Haldex conversion kit also mounts to the original rear-axle crossbeam and syncro diff mounting points, this is the mounting point that bolts the rear of the syncro diff to the body. No need in shortening the propshaft.
For those interrested we had several sets cut and can supply this as DIY package, means you need to do the welding yourself, however the separate parts are tack welded for reference, no jig included.
A gearbox 02M mount is also avaliable to mount the 02M gearbox in the MkII/III platform, Please contact me for pricing.
Below are the pictures of YELLOWSLC's rear axle that has been converted this weekend.
More pictures on: http://www.dutchdub.com/Forsale.htm
New style 02M mount:
Modified by Dutch1967 at 1:37 PM 5-29-2005
Modified by Dutch1967 at 8:32 AM 9-22-2005
Modified by Dutch1967 at 2:25 PM 2-29-2008
Modified by Dutch1967 at 2:22 PM 10-24-2008
Modified by Dutch1967 at 2:24 PM 10-24-2008
Stay tuned..
