Quote, originally posted by PAR75 » |
I'm thinking of swithcing to synthetic oil. My VR6 has 107,000 miles on it and I'm not sure if it's had synthetic before (I'm the 2nd owner, bought it at 77,000). Are there any potential issues with seal damage or anything like that? |
Quote, originally posted by 300B » |
There is only a potential for seal problems to show up is if they already exist.Whatever type of oil you end up using it is important to use the right viscosity for your climate.Many here use Mobil 1 0W40 year round as it covers all bases temp wise. Here's a website to visit if you wanna learn more about oilhttp://www.bobistheoilguy.com BTW, Delo 400 15W40 is a good alternative to a synthetic in temps above 32f for your VR6. Alan ![]() |
Quote, originally posted by littlenr » |
if 0w-40 is good enough for them thats your choice. Its not really the weight that matters. Its how offten you change it. If you want to look at oil rating in one manner look at it this way. The leading number is the cold viscosity rating. The second is where the viscosity goes when the oil is up to its running temp. While 0w-40 is low in viscosity while cold that means it does not have any resistance to flow. Good on cold start. What you can't read between the lines is most oils do not have a protection number. This is the "residue"; if you will, of oil that stays on metal after sitting for a while. Cold starts are the most important time for protection. A 0w will flow nice but does it protect is the real question! |
Amsoil is the way to go for synthetics. |
I am a Amsoil distributor .... |
