1 - 8 of 8 Posts
T3 ... It's time to replace the brake pads and sensors . Looking for advice.
I've done the search , most of the posts are older that I'm come across .
I'm hoping for some current information for our 14 Touareg TDI pad and sensor replacements .
Thanks in advance !
What do you need?
If parts, hit up @Qpower1 on club touareg - he can get OEM gear for cheaper than dealer. Do NOT go other than OEM on the Touareg or you'll lose significant braking power and longevity
I second only use OEM.
I have had issues when I used aftermarket brake pads. I put aftermarket pads on my 2018 Tiguan, and replaced them with OEM after a year since the aftermarket didn't fit correctly and would move in the calipers. If I backed up and applied the brakes, and then when forward and applied the brakes the pads would shift in the calipers making a slapping sound. NAPA gave me new pads, but wouldn't refund my money since I didn't have the box. I used Eurostop aftermarket pads on my Touareg, and those seem to be OK, but I didn't use any of the replacement hardware since it was slightly different from the original, and the existing hardware was fine.
I second only use OEM. I have had issues when I used aftermarket brakes.
Plenty of cars benefit from aftermarket brakes.. the quad-piston OE Brembo setup on the Touareg, does not.
I put on the Akebono "European" pads and they have way MORE stopping power, less dust and have not made a sound. Unfortunately they don't make a rear pad (or that I have found yet) so I went with the HAWK rears.
This is the third VW I have used the Akebono pads on and have been very happy with all of them.
1 - 8 of 8 Posts
